93 f150 2wd coil spring and shock ?
Old Apr 14, 2010 | 05:54 PM
Tannerf150's Avatar
Hi guys, I'm looking into buying a set of 2' lift coil springs from a place called broncograveyard, and My dad wasn't for sure if I could use new stock shocks for it or lift shocks I think I need lift shocks but all they have on the site are 1.5 inch to 4 inch no inbetween now will a 1.5inch shock work with my 2' lift coil springs? or do I need to keep looking for a 2' lift I'm just looking for a gas shock nothing hardcore the one I'm looking at is rough country gas shock
Old Apr 15, 2010 | 01:22 AM
Optika1 illushu's Avatar
the lift shock will work for that specific range because it has more travel. u will be fine with that shock. the stock shocks are very short on these trucks, one of the reasons they have such little travel.
Old Apr 15, 2010 | 09:59 PM
Tannerf150's Avatar
Alright thanks
Old Apr 15, 2010 | 10:00 PM
Tannerf150's Avatar
Also do you know if I need anymore to lift it the 2 inches? the LMC add said 2' lift coil spring and I'm buying it from bronco graveyard for cheeper I didn't know if i needed more or not I think I only need the shocks and coils
Old Apr 16, 2010 | 12:25 AM
MI02SVT's Avatar
you shouldnt need anything else 2 inches seems like alot but when you actually put it on and all the weight is on the suspension youll prob have about 1.5 maybe and after it all settles in about 6 months to a year youll prob have about 1 inch of lift
generally you dont need anything until you go 3 or more then you need brake lines
you shouldnt have a problem
Old Apr 16, 2010 | 12:53 PM
Tannerf150's Avatar
Well if I get a 3' will I only need brake line extensions and will the 1.5 inch lift shock work with the 3' as well?
Old Apr 22, 2010 | 10:36 PM
MI02SVT's Avatar
if you get a kit they will give you everything you need to do it and there fairly easy to do it took me a day to do mine when i did my 6 inch lift you shouldnt have a problem just do some shopping around to see what kit you like sorry it took so long to respond i been busy
Old Apr 23, 2010 | 06:11 PM
GTRider245's Avatar
Don't do anything above a leveling coil (1.5-2 inches) without a full lift kit with drop brackets. Even with the leveling coils, you may need new camber bushings to get it to align right afterwards.
Old Apr 23, 2010 | 10:57 PM
Tannerf150's Avatar
Where can I find drop brackets and how much do they cost?
Old Apr 24, 2010 | 03:14 PM
GTRider245's Avatar
In a lift kit. They start around 400 dollars.
Old Apr 24, 2010 | 08:03 PM
x2, do it once and do it right bud.
Old Apr 26, 2010 | 07:20 PM
Tannerf150's Avatar
Well I only plan on getting a 2 so I can level it I don't plan on goin to big as law requires less then 3 inch body or suspension lift.
