Want to convert my fi to carb, 91 5.0
Hi great site! I just receantly purchaced a 91 f 150, with a 5.0 and E4od tranny, does any one know if I can convert it back to a carb and electronic distrubter? I like old scool.
I'm sure it can be done, but why? Unless something is totally messed up with the fuel injection system, I see no reason to go backwards. I'm also old school, but I like the fuel injection over a carburetor. If it aint broke, don't try to fix it.
http://wiki.answers.com/Q/How_do_you...V8_small_block
ive seen on powerblock they showed how to convert but i couldnt find it...i dont see a point in it myself
real men carb it out. im just did the same thing on my 91 f150. look at some of the pics in my gallery. tommorrow ill get you the summit part numbers you need for the intake and such, youll need to find your own carb tho cuz i got one for free, any square bore will work, i recomend a edelbrock performer. the get a mallory distributor ( doesnt have to be mallory i just perfer them) and a mallory cdi box and your in business.
Hi Guys thanks for the advice, Big daddy I am thinking the same thing about the intake carb and ignition, however my biggest concern is the tranny, Do you have a E4OD tranny? I hear there is a kick down adapter like from a place by the nane of LOCAR? I;m also concerned about running a fuel pressure regulater, have any problems there?Lookin forward to your reply, thans.
your going to have to cut apart your engine wiring harness and take the fuel infected crap out, and leave you sensors and whatnot in place. thats what i did and i havent run into any probs yet. the kickdown cable bracket you need is by lokar and the part is # LOK-SRK-4000 it costs 24 bucks.
anyway i went with:
an edelbrock performer rpm intake- part # EDL-7121-$169.95
intake manifold bolt kit- part # EDL-8524-$24.25
a couple carb base gaskets- part # SUM-G1418-$1.95 each
some carb studs-part # SUM-G1423- $5.95
and a head gasket kit-part # EDL-7220- $14.95
for a carb im runing an edelbrock performer that i got for free but you can get them at autozone for 300 bucks, and i also have a carb space plate that was like 20 bucks. if your not going to run a spacer plate you only need 1 base gasket.
hope that helps
-Phill
anyway i went with:
hope that helps
-Phill
anyway i went with:
hope that helps
-Phill
kingfish- i used "T" fitting and ran a return line and then after the t i put in a regulaor
strangeranger- i left my electrical system intact all of my sensors are still in place, i just cut the fuel injection out of the harness, havent noticed any issues yet
If your tranny is cable operated, it's an AOD not an E4OD.
dang major brain fart, i totaly ignored the fact that you said e4od. yeah i dunno what your gonna do with that little guy. id call summit tho, they always have a fix. the # is 1-800-230-3030
