no engine power???
Old Feb 15, 2010 | 07:11 PM
jeff32b's Avatar
no engine power???
hi, i have a 1994 f150. the other day i was driving down a rough road, and i got to a snow bank so i gave it some gas to get through, and the engine just bogged down, and tires stopped. i put it low range and got out just fine. a little while later on the highway home, the truck had no power even with my foot to the floor, i couldnt get up to the speed limit. the next day everything was fine. this has happened a few times and i was wondering if anyone had any ideas what it was??? any help would be appreciated
Old Feb 15, 2010 | 09:18 PM
Change your fuel filter, and have a muffler shop test your cats for clogging with an infrared tester.
Old Feb 17, 2010 | 01:47 PM
ymeski's Avatar
Error Code scan results will also help. Not sure how or why, but Clogged cats will act up sporadically at first, but will progressively worsen in intensity & frequency. You can temporarily remove the o2 ahead or the cat when the problem occurs, to see if the drivability problem goes away, implying a back pressure issue.
Old Feb 18, 2010 | 09:20 PM
jeff32b's Avatar
thanks, gonna change the fuel filter tomorrow, then hit the cats if its still no good
Old Mar 2, 2010 | 06:51 PM
jeff32b's Avatar
update: i changed the fuel filter, and air filter, this made a great improvement. about a day later my exhaust started leaking at the cat, so i removed it temporairily and replaced it with a piece of pipe while waiting for a new one. i have driven the truck a few times and it is running significantly better, but still looses power occasionally (not nearly as bad as before) i have no check engine light, and no other problems. any ideas?
Old Mar 2, 2010 | 07:39 PM
ymeski's Avatar
Error code scans
