guages
Old Feb 7, 2010 | 11:39 PM
Cashew's Avatar
guages
so i made a thread a couple days ago about my water temp sensor that wasnt performing correctly. well thats not the only guage not performing correctly.
when im using my rear tank, my gas guage goes down way quicker then it should. pretty much a half tank in a day, and thats prolly 60 miles at the most.
also, my battery guage is whacked out also. it shows that its preforming at around 3/4 up the guage. i got a brand new battery and it still happens.
have you guys ad any troubles like this?
Old Feb 8, 2010 | 12:49 AM
MTM Ford's Avatar
Sounds like your cluster is the problem. Kind of strange how all the gauges are screwed up.
Old Feb 8, 2010 | 10:21 AM
Cashew's Avatar
have any idea on how to fix it?
Old Feb 8, 2010 | 11:45 AM
MTM Ford's Avatar
Probably best thing to do is get another cluster and put it in then have Ford reflash the new cluster so it shows the correct miles.
Someone else may chime in and tell you something else to try, but this is probably what I would do.
Old Feb 10, 2010 | 03:15 PM
ymeski's Avatar
Sounds like a grounding problem. Fussin around wires under the dash recently.
