VSS Sensor?
Old Jan 30, 2010 | 11:29 AM
T_Dawg's Avatar
VSS Sensor?
I have a 1995 Ford F150 XL 2WD with the 4R70W Trans, recently I have been expieriencing some problems with pulsng brakes. I checked all mechanical parts, all seem good. I was thinking this was an ABS problem. So my question is will replacing the VSS sensor help my ABS problem?
Old Feb 5, 2010 | 09:34 AM
Steve83's Avatar
You don't know that you have an ABS problem, and blindly replacing parts isn't likely to fix anything. Diagnose first; replace parts later. Read this caption:
Then click my black Bronco in my sig, scroll down to the Brakes & Hubs album, then scroll down to the diagrams that relate to RABS & RABS-II, and read their captions. Ignore the 4WABS stuff - you don't have that.
Old Feb 11, 2010 | 06:18 PM
T_Dawg's Avatar
problem fixed
Steve thanks for all that info, turns out it was a very bad set of rotors. I replaced them and brakes are fine, no sensor problems at all.
