fuel filter stuck
Old Jan 27, 2010 | 04:28 PM
fanboy1982's Avatar
Question fuel filter stuck
i have a 92 f150, trying to replace the fuel filter. the guy who had it before me put the filter on backwards, i have been trying to get it off but it simply wont budge. any ideas to get this thing off? and before you ask yes i have the correct tool to remove the filter it just doesent seem to be working. thanks
Old Jan 27, 2010 | 07:43 PM
Dynacologist's Avatar
My personal trick is drink beer cuss and eventually it will come off, you can have a 20 minute rant on who the XXXX designed the pos. Works every time.
Old Jan 27, 2010 | 07:47 PM
fanboy1982's Avatar
yup
well so far i have been thru a 12 pack and every cuss word i know, still no luck.
Old Jan 27, 2010 | 07:49 PM
coorsracing28's Avatar
i just replaced mine, the little metal tabs inside usually get bent, so i just take a small flat head screw driver and pull on the filter away from the line that your trying to get off, and use a flash light to look down in the end your getting off, and you might be able to pinch down the metal tab and then pull on it till it comes out a little bit, then try to get the rest of them the same way, or use multiple small screwdrivers, thats how i got mine out, or just pull really hard on it til it flies out and fuel goes everywhere, might need to get a new metal clip but atleast it will be out.
Old Jan 28, 2010 | 08:58 PM
Steve83's Avatar
Read this caption:
Old Feb 12, 2010 | 01:18 PM
95rangerman's Avatar
Hey fanboy,
Where do you get the special tool for the filter removal? I picked up the filter today and then began searching forums. Thanks for any suggestions.
I have access to autozone, carquest, napa, and advanced auto in town.
Old Feb 12, 2010 | 10:09 PM
ymeski's Avatar
Everybody carries em. About $5 a set. (multi sizes).
