393 Stroker for my 92 Flareside
Old Dec 30, 2009 | 07:00 PM
nflfreak43's Avatar
any suggestions on 393 Stroker kits that are reasonable say up to 1500 dollars. and what cam should i go with? oh and i will be doing a MAF Swap. will be probably getting GT40 heads for it also along with Long tube headers.
Old Dec 31, 2009 | 03:42 PM
Veteran: Army
do a custom ground cam, designed for the stroker, or else you'll end up with pumping loss
Old Dec 31, 2009 | 03:45 PM
Veteran: Army
also you're gonna need to upgrade the fuel system and it'll be advisable to do some head work
Old Jan 3, 2010 | 04:26 PM
nflfreak43's Avatar
was starting to aim towards a 393 stroker but decided not to just for the pure reason this is my DD and i dont want it to crazy. and i was looking at the power numbers and i can get nearly the same power from the setup ive settle on. so here is what my setup will be.
MAF SWAP!
Comp cams Magnum 270 grind cam and matching valve springs.
Typhoon Intake upper and lower to match the GT40 heads.
GT40 Heads
Long Tube headers
so what yall think?
