460 in a 86 F150????
Old Dec 13, 2009 | 02:08 AM
07 FX4's Avatar
Talking 460 in a 86 F150????
Okay, So im about to get an 86 F150(5.0L, single cab, short bed, 2WD) but this 302 is pretty much gone So my question is how hard will it be to swap out this 302 and the AOD tranny to a 460 and maybe a E4OD or C-6. My Buddy has a 460 off a 79 f150...If this is possible I will most likely jus slap a carb and be done with it....Any taughts will be greatly appreciated
PS I know I will have to change the fuel pump if I put a carb, anything else I should look at??
Old Dec 13, 2009 | 02:13 PM
ymeski's Avatar
Your family must own a Gas Station? Cool! C-6 was stock on 79's w/ auto trans.
Old Dec 13, 2009 | 02:52 PM
07 FX4's Avatar
haha!! that would be the ONLY down side lol....you think im gettin my self into a mess with this swap???
Old Dec 13, 2009 | 02:55 PM
FATHERFORD's Avatar
been there done that....
http://www.youtube.com/watch?v=NJIyspXy69k
easy easy swap, just buy f-250 stuff.
Old Dec 13, 2009 | 03:00 PM
Veteran: Army
real easy swap
Old Dec 13, 2009 | 03:05 PM
FATHERFORD's Avatar
real easy swap
Yep, I really aught to get my 87 back going... Just need to finish the rear end in it.
Those trucks with 460's in them weigh 3600lbs.... That is LIGHT for a truck. 600hp in a 3600lb truck will move.
Old Dec 13, 2009 | 03:13 PM
ymeski's Avatar
Very doable! So is your gas station open late on Sundays? Alot of em are closing early nowadays! Don"t punk out on the Ignition system and bump the timing to at least 13.5BTDC! http://fullsizebronco.com/forum/show...ht=timing+bump They like this too http://performanceunlimited.com/docu...degapping.html
Old Dec 13, 2009 | 09:05 PM
07 FX4's Avatar
so to make it a little easier, jus look for a donor f250 powertrain and swap it in!! lol
Old Dec 13, 2009 | 09:25 PM
FATHERFORD's Avatar
doesn't really matter. My 87 had an i6/c6 combo. Just use different engine mounts... same tranny crossmember, same drive shaft, etc.
It's no big deal at all.
Old Dec 25, 2009 | 03:14 AM
redx's Avatar
Many many trucks ago I had my 86 that I wanted a 460 in it. Now I am older and still want a 460 in a 86 but I can't do it until I get the 67 done, one project at a time.
Old Jan 3, 2010 | 11:57 PM
07 FX4's Avatar
what about my rear end???? 8.8 seems kinda weak or should it be enough??
Old Jan 4, 2010 | 07:04 AM
StrangeRanger's Avatar
The E4OD will not run without a computer. A standalone controller is available from Baumann. http://www.becontrols.com/
Otherwise save yourself some grief and go with the C6
The 8.8' rear end will be debated forever. The biggest problem is the weak carrier. Consider an Eaton limited slip, a Detriot Truetrac or a Detroit Locker. Any one of them will improve your traction and eliminate the weak stock carrier. Or you could convert to a 9"
Old Jan 4, 2010 | 08:14 AM
FATHERFORD's Avatar
I ran an 8.8 in mine. If you plan on slapping slicks and launching off a trans-brake I would go ahead and put a 9" in it.
Old Jan 4, 2010 | 01:38 PM
c_pollard's Avatar
very easy swap just save yourself the headache and hassle and go with the c6 though and look for an after market ign I beleive there is one on ebay from procomp for around $300 with everything you need gas really is all that bad aslong as you keep it off the floor also have you gave ne thought to headers (with the gas prices up its good to see someone else not afraid to go bigblock)
Old Jan 4, 2010 | 09:47 PM
07 FX4's Avatar
well I have my buddies 460, all I have to do is pick it up...next is to go look for a C-6. BUT this project will take a lil longer than expected(just got laid off today)
thanks for the help guys
BTW I just want this thing for around town as my daily lol. No launching...MAYBE
