Speedometer Gear...
Old Nov 28, 2009 | 06:43 PM
blown8950's Avatar
Speedometer Gear...
Hey guys, I'm working on a 1990 F-150 4x4 with the 5.0 and the E40D transmission. I need to know where I can get the speedo drive gear, the one inside the tailshaft housing of the transmission, since they're no longer available from Ford. The speedometer works if I use a drill on the pinion gear on the end of the cable, but once I reinstall it in the tranny it no worky. Also, to those who've done it, how tough of a job is it to replace? I'm pretty mechanically inclined. Thanks.
Old Nov 28, 2009 | 07:34 PM
StrangeRanger's Avatar
It's not a separate gear, it's machined into the tranny tailshaft.
Did your tranny get rebuilt at some point in the past and did the builder use a tailshaft from a 93-96? Those years get the vehicle speed signal from the diff so they don't have the gear in the tailshaft.
Old Nov 29, 2009 | 01:47 PM
Steve83's Avatar
It's not in the trans - it's in the t-case tailhousing, and it's a slip-on plastic gear. It's not shown in this '92-96 diagram because they used the rear diff, but it would be where 10 is shown, inside the tailhousing behind a snap ring. If you pull the VSS out of the tailhousing, you should be able to see the gear teeth with a flashlight & mirror. If they appear to have a crescent missing from each tooth, you've diagnosed it correctly.
If you end up NOT being able to find that gear, then it's not very difficult to swap a '92-96 PSOM into your cluster & wire its output to your EEC so it can control the E4OD. But you may have to also swap to a '92 EEC for it to accept the PSOM signal - I'm not sure.
Old Nov 29, 2009 | 06:37 PM
Doh!
I missed the 4WD in your truck description. The transmission related speedo drive you were asking about is all 2WD. Like Steve said, the 4WD takes it off the T/C
