Block Heater
Old Nov 23, 2009 | 02:57 AM
andrew_516's Avatar
Block Heater
This is a pretty noob question but, i can i tell if my block heater is working? The reason why i ask is ive touched blocks with brand new heaters and at -20 to 0 degrees nothing feels hot.
Old Nov 23, 2009 | 03:07 AM
Paralyzer's Avatar
u can use an ohm meter on the 2 main prongs but its not as good of an idication as load testing the circuit. The best way is to take a test lead and hook it to your battery + and then to one of the 2 main prongs on the cord(make sure no connections are touching bare metal befor the next step) then take a test light and put it between your battery - and the remaining prong on the cord. If the test light lights, your block heater is good
Old Nov 23, 2009 | 03:28 PM
andrew_516's Avatar
sweet, thanks for the reply. i knew there had to be a simple way to do that.
