No brake pedal
Old Oct 28, 2009 | 09:53 PM
fsckedagain's Avatar
No brake pedal
OK, so I went to replace master cylinder (didn't bench bleed it, I'm a fool) because I only had about the last 2 inches of pedal to apply brakes but I get zero fluid to the rear at all when trying to bleed them.
It's a 1986 F150 4X4 302 EFI/AOD. Is this a byproduct of not bleeding the MC first? or could there be something in between jacked up?
Old Oct 29, 2009 | 11:46 AM
chris_9891's Avatar
is it a split resivoir
Old Oct 29, 2009 | 04:38 PM
If you mean separate reservoirs, yes, not separate from the body of the MC like a plastic reservoir on the MC.
Old Oct 29, 2009 | 05:28 PM
chris_9891's Avatar
yea thats wut i meant, one of the pistons in the MC is probably stuck in front of the line, you might need to take it off and bench bleed it
Old Oct 29, 2009 | 07:55 PM
Yeah, I am going to do that tonight. I am also going to do both the wheel cylinders and pads in the back tomorrow. I am going to make sure the brakes work by Saturday so I can drive this damn thing
