Body Lifts
Old Oct 12, 2009 | 12:07 PM
SouthernMan09's Avatar
Body Lifts
I have a 1995 2wd F150 and thinkin about puttin a body lift on it. Does anyone know where i can get a body lift kit with the rear relocation bracket. almost all of them come with the front one, but nobody seems to have the rear bracket. Any help?
Old Oct 12, 2009 | 02:56 PM
aswaff400's Avatar
i dont think anyone makes a back relocation kit, i just took the brackets that i had, flipped them upside down, swapped sides, lined everything up drilled 1 new hole on the frame rail on either side... only took maybe 30 minutes to do...
Old Oct 12, 2009 | 03:10 PM
so do you think body lifts work, i mean looks wise. Thats the only reason i want to lift my truck.
Old Oct 12, 2009 | 03:36 PM
aswaff400's Avatar
to keep the factory ride yeah BL's work, i had to install mine after my lift springs settled and caused the tires to rub the fenders... me and one buddy had my entire BL on in less than 8 hours in my driveway...
heres what i did for the back brackets:
originally the brackets angled downward slightly... with a 3" B.L. the brackets work perfect almost parallel with the frame:
my bumper was almost perfectly level but is now angled slightly downward after backing into a tree
Old Oct 12, 2009 | 05:10 PM
Thanks man thats awesome. That works really good, it looks like.
Old Oct 13, 2009 | 01:09 PM
GTRider245's Avatar
All good examples of why you should a suspension lift instead. Body lifts are a cheap way of doing what a properly designed suspension lift does.
