1989 F-150 High idle problem
I have a 1989 F-150 with the fuel injected 5.0L and automatic transmission. It has been sitting for a couple of weeks, and just today I started it up to take out some garbage. I noticed that when I slowed down and the engine got to about 900 rpms, the rpms suddenly jumped back up to 1100-1200. When I placed the vehicle in park, the rpms shot up to 2500+. When I restart the truck, the idle started out at about 1500rpm or so, then went right back up to 2500 rpms.
I took off the IAC and cleaned it up, and it appears to be functioning. I also unplugged the IAC while the truck was running, as I was told if there was an intake leak the truck would continue running. However, when I unhooked the plug from the IAC, the truck died out.
The last time I used the truck it ran fine, so I'm at a loss. Any ideas or suggestions?
If you figure it out please let me know. I've had the same problem with my truck for a while. I replaced several things (returned most when they didn't work): O2, IAC, TPS, cap/rotor/plugs, ACT, and the water temp sensor.
At this point I suspect it to be a problem with the thermocater but have not yet figured that one out.
The plot thickens
Today when I started my truck, the rpms shot up to 2000, then immediately came back down to 700-800. It was idling very rough, and my "Check Engine" light came on. If I would give it any gas, it would bog down a bit, then pick back up. Again I tried unhooking the plug from the IAC and the truck would stall out.
Anyone have any ideas at all? I'm completely stumped here.
Well, going by my CEL, I'm getting a Code 23: Throttle position sensor. It's not able to idle for long at all anymore, and will stall out if I try to drive anywhere. Does this sound about right to anyone else?
