85 f150 2" lift with 33's?
Old Sep 22, 2009 | 09:46 PM
gears2's Avatar
i have an 85 f150 with 31 10.5s on it and have already bought heavier rear springs that should lift the rear about an inch but i'll get an additional inch with blocks. up front i wanna get 2" proggresive rate springs. will 33's clear? and also i've heard 8" wheels are the absolute skinniest wheels you can go with for 12.5 tires. should i be fine on my 15x8 aluminum wheels? thanks for any help
Old Sep 23, 2009 | 05:29 AM
StrangeRanger's Avatar
8" is too narrow. According to most manufacturers 33 x 12.5-15s require at least an 8.5" rim
Old Sep 24, 2009 | 06:40 AM
adrianspeeder's Avatar
33's gonna clear 80-86 trucks and bumpers stock.
Adrianspeeder
Old Sep 24, 2009 | 11:42 PM
letsgosteelers8's Avatar
an 8" rim will definately be pushing it. I know some guys do it but its not really a good idea, basically a narrow wheel "rounds" the tire out and messes up the wear. Its up to you though...post pics when you get done.
Old Sep 25, 2009 | 01:59 PM
GTRider245's Avatar
Stop this crazy talk. I have ran 33x12.50s on an 8" wide rim for a while with fine results. Got almost 40,000 miles of EVEN treadwear from a set of Firestone M/Ts and on a set of BFGoodrich M/Ts now that are also wearing even.
Old Sep 25, 2009 | 02:47 PM
Both of those manufacturers say that an 8.5" rim is the absolute minimum safe width for that size tire with a range of 8.5-11.0 with 10" being the width at which they quote the tire dimensions, loads, etc.
Old Sep 25, 2009 | 06:11 PM
GTRider245's Avatar
Every lift manufacterer will also tell you that a 4 inch TTB lift is designed for 33 inch tires, yet we know we can fit 35s with a 4 inch kit. Sometimes you have to look past the obvious. I dont know about now, but back in the day Rancho speced the 4 inch kit for the 80-96 trucks to run a 33x12.50 on an 8 inch wide wheel.
EDIT: they still do- http://www.gorancho.com/assets/Wheel_chart.pdf
I have 35x12.50 BFGoodrich KM2s on my 2005 with stock Lariat wheels. Once again, even tire wear.
I have ran a 12.50 wide tire on stock 92-96 rims which are 7.5 inches wide, once again with no problems. The fact is, its an inch out of the manufacterer's "spec". It is not that big of a deal.
Old Sep 25, 2009 | 07:51 PM
It's not tire wear that 's the issue. Tire manufacturers love premature tire wear, it helps them to sell more tires. What they do not love is lawsuits stemming from the tire rolling off the rim. It's not just the stability of the tire on the rim either, it could also involve the integrity of the bead seat. If it's designed for 10" wide rims use 10" wide rims or go to a narrower tire on the 8s.
Old Sep 25, 2009 | 10:32 PM
GTRider245's Avatar
I am not debating that at all. You are trying to say that a tire designed for an 8.5" wide wheel shouldnt be ran on a 8" wheel, and that is just crazy.
Old Sep 26, 2009 | 06:27 AM
It is not designed for an 8.5" rim; it is designed for a 10" rim. The allowable range of widths is 8.5"-11.0". That means that 8.5" is the absolute minimum rim on which they should be fitted.
Old Sep 26, 2009 | 12:41 PM
gears2's Avatar
alrighty thanks guys. by the way does anyone know the height in inches of 80-96 stock coils? thanks. i just got the coils in and i'm gonna clean up the leaves this afternoon. what do u guys think would be a reasonable price for 4 33x12.5x15 mud terrain tires (their mud king tires) with 60-70 percent tread left on them. and the guy will be mounting them for me
Old Sep 27, 2009 | 01:40 AM
GTRider245's Avatar
Either way, a half inch isnt going to matter. They will run fine on an 8" wide wheel.
Old Sep 27, 2009 | 06:40 AM
If the half inch wasn't going to matter than the manufacturers' published data for rim sizes would say 8.0"-11.0" but the data doesn't say that, does it? So we're left with a problem. We have to decide whether the industry engineers who designed them to work within a certain set of parameters and who have hundreds, if not thousands, of hours of test data to support their designs know more about tires than you do.
Old Sep 27, 2009 | 06:51 PM
gears2's Avatar
well i found some nice 33's on 10 inch rims so i won't have to worry about wheel width now, but does anyone know the length of 80-96 stock coils?
Old Sep 27, 2009 | 10:21 PM
GTRider245's Avatar
Tell that to the thousands of people running 12.5" wide tires on wheels less than 8.5" wide.
Do you apply that method of thinking to every aspects of automotive modifications?
