is this possible?
Old Aug 26, 2009 | 10:31 PM
xltplower's Avatar
is this possible?
is it possible to take a 95 and up e4od trans and put it into my 92 f150 4x4?
Old Aug 27, 2009 | 01:23 AM
Matts ford's Avatar
as long as you use a computer for the e40d and the computer is tuned for the engine in the 92 then yes it will work. what trans does the 92 have? is the e40d from a 4x4? driveshafts may be different if the transmissions are different. tell us what each of the trucks have and we can tell you what you'll need. the bellhousing from a modular v8 will not match up to your engine though so you gotta make sure that the trans is from a pre-97 truck.
Old Aug 27, 2009 | 06:04 AM
StrangeRanger's Avatar
The pinouts on the connectors may be different. There were some changes year to year.
Old Aug 27, 2009 | 09:49 PM
xltplower's Avatar
ok i am driving a 92 f150, E40d,im not sure of the transfer case i know its a borge and warner, 5.0, and i plow, i was having a slamming into gear and stalling when put into reverse,also shifting funny and not fully engaging into over drive, i hear that the 95 E40d trans are better, i have been trying to get my trans out and a bellhousing bolt broke off (one that holds the trans dip stick) and now i cant get it to brake from the engine, any advice?
