Lift?
Old Aug 13, 2009 | 10:45 PM
cheeksea217's Avatar
Lift?
1995 ford f150 inline 6
im wanting to lift my truck 3 or 4 inches, what would be the cheapest way to go?
would it be possible to add a leaf in the back and put on some taller coil springs in the front and be done with it? or is there more to it?
Old Aug 15, 2009 | 02:56 AM
letsgosteelers8's Avatar
yeah that would work. a 3" BL would be cheaper. depends on how cheap you want it to be.
plus you'll only get about 2-2.5 in for the AAL and coils.
Old Aug 15, 2009 | 09:42 PM
DAsteve's Avatar
get a 3in body lift if you want to go cheap...
Old Aug 16, 2009 | 02:35 AM
...also, if you want to go higher you will have more options later if you do a BL now
Old Aug 17, 2009 | 12:38 PM
Will i have to extend my brake lines or anything if i do a 2.5 or 3 inch lift?
Old Aug 17, 2009 | 01:48 PM
F150TX's Avatar
I have looked into body lift in the past, but they would always have a note in small print that would say, not for 6 cylinder on 92-96. Does anyone know what causes the problem on a I6? Never researched it much
Old Aug 24, 2009 | 12:40 AM
nope
Old Aug 24, 2009 | 01:14 AM
http://www.performanceaccessories.com/catalog/ford.htm
should find what you need here...
Old Aug 24, 2009 | 03:34 PM
F150TX's Avatar
Thanks for the info steelers8, sorry to hijack the thread. Looks like the radiator hose is note I was not sure about.
Old Aug 25, 2009 | 09:05 AM
There is a write-up on this site somewhere about moving the hose...try searching you may find it. I'm pretty sure it has good pics to help.
...here it is, posts 8 and 9 give an explination and show an after pic. The whole thread might be helpful
https://www.f150online.com/forums/su...hose+body+lift
