1.7 Rocker Arms
Old Jul 9, 2009 | 11:20 AM
LostAtSea85's Avatar
1.7 Rocker Arms
I've got a set of Crane Cam 1.7 ratio rocker arms I'm about to put in my 5.0. Will the stock valve covers have enough room for the rocker arms to clear, or will I need a bigger size?
Old Jul 9, 2009 | 12:03 PM
StrangeRanger's Avatar
On a 5.0 Mustang, the stock valve covers require a little clearancing on the baffles to fit, don't know for sure about the truck covers
Old Jul 9, 2009 | 12:30 PM
GTRider245's Avatar
You should be fine.
Old Jul 9, 2009 | 01:11 PM
Sparkadellic's Avatar
I installed Crane Cams 1.7 roller rockers on my 5.0 also. I had the motor out when I did it so I was able to put them on and rotate it, making sure there was no clearance issue. All was good
Old Jul 9, 2009 | 01:26 PM
Awesome. Thank you.
