94 stalls intermittently
Old Jul 5, 2009 | 04:54 PM
bigjon460's Avatar
94 f-150,302,at,yada yada yada runs good but intermittently surges and/or stalls. IAC has been replaced 2 time but doesn't seem to help. other than this truck runs great nice and smooth. this is driving me nuts any suggestions
Old Jul 6, 2009 | 08:53 AM
subford's Avatar
Any codes?
Old Jul 6, 2009 | 11:39 AM
Steve83's Avatar
https://www.f150online.com/forums/pr...tting-out.html
Old Jul 6, 2009 | 07:11 PM
bigjon460's Avatar
no codes on one of the occasions that I replaced the IAC the was a code for that but none at this time
steve83: not cutting out like that doesn't act like a ignition or a fuel problem usually dies when turning into a driveway or it will surge while doing the same no ryme or reason very sporatiac otherwise runs smooth and always starts right back up and runs smooth afterwards
Old Jul 6, 2009 | 08:09 PM
Matts ford's Avatar
does it make a difference wether you let off the throttle fast or slowly take your foot off the throttle? whats the fuel level when it happens? is the battery held down tight? cables clean and tight? pcm plug tight? has anything else been done to it since it started other than the iac?
