1994 F-150 Lightning 5.8L
Old Jul 4, 2009 | 01:43 PM
EvanBaker's Avatar
i have an issue with my 94 f-150 lightning 5.8l with about 140K, when i let it sit over night or even about 8 hrs of being at work when i start it up i get a rapping noise from the right side of the engine like it looses oil pressure, sounds like a rocker or push-rod issue just curious if anyone else has had this issue. think is should add some Wynns 50+ to oil change im running 10w30 and i live in Maine, USA, i recently purchesed intake gaskets n what not assuming its my rockers or pushrods, just wanted some feed back b4 i rip it apart. Thanks alot,
Evan
Old Jul 4, 2009 | 06:40 PM
Sparkadellic's Avatar
How long does it take for the noise to go away? It could possibly be a stuck lifter. I've had that happen to me before and it made a tapping noise.
Old Jul 4, 2009 | 07:00 PM
EvanBaker's Avatar
tapping noise
about 10 seconds or 15 depends on how long it sits
Old Jul 4, 2009 | 07:07 PM
EvanBaker's Avatar
tapping noise
Old Jul 4, 2009 | 11:44 PM
Steve83's Avatar
I suggest this before you tear into it:
http://www.nloc.net/vbforum/gen-1-lightnings/
This doesn't apply to your truck, but it's worth reading.
Old Jul 5, 2009 | 10:05 AM
EvanBaker's Avatar
yeah it does
yes it does mines a gen 1 lightning suppost to be white but its red now with a black stripe
Old Jul 5, 2009 | 03:46 PM
EvanBaker's Avatar
thanks for the tsb how can i tell if its the check valve making that noise?? by having someone start it and have my hand over it?? thanks!
Old Jul 6, 2009 | 11:30 AM
Steve83's Avatar
What are you talking about? Does your L have a 4.9L engine?
What does that have to do with engine noise?
But I only posted it to illustrate how 'engine' noises don't have to come from the engine. In another thread (on another BBS), a guy thought his oil pump had gone bad & wanted to know how to change it. Turned out his starter Bendix wasn't retracting. The point is: don't jump to a conclusion. Get a mechanic's stethoscope & pinpoint the sound before buying or disassembling anything.
