how much can it handle?
Old Jun 26, 2009 | 07:25 PM
Matts ford's Avatar
alright 93 f150 5.0
i know a bone stock aod couldnt handle much more than a stock engine. but my trans is a reman from rmp(it says motorcraft) and its suppose to have all the updates done to it. how much hp/tq should it be able to handle without a problem?
Old Jun 26, 2009 | 08:42 PM
StrangeRanger's Avatar
What tranny?
The 4R70W/AODE is rated for 700 ft-lbs at the input shaft but you have to factor out the torque converter so figure on somewhere around 320-350 ft-lbs from the engine. For the E4OD, it's 1000 ft-lbs at the input shaft so somewhere around 450-500 ft-lbs from the engine.
Because of the weak 2 piece input shaft the old AOD was a lot lower, probably somewhere around 300 ft-lbs.
Old Jun 26, 2009 | 08:49 PM
Matts ford's Avatar
Originally Posted by StrangeRanger
What tranny?
aod
Old Jun 26, 2009 | 09:08 PM
Matts ford's Avatar
What tranny?
hmmm. alright. well i'm at or over 300 ftlbs right now at the crank. oh well if it breaks when the warranty is over i'll put in a 5 spd. thank you
Old Jun 26, 2009 | 09:41 PM
If you can live without the lockup torque converter, put in an upgraded AOD with a one-piece input shaft and all the performance bits and pieces. Properly built an AOD will take whatever you throw at it.
Old Jun 26, 2009 | 10:04 PM
Matts ford's Avatar
yea. but i would like o/d. i think i might just swap in the heavy duty zf5 if i have a problem with this aod. plus IMO first gear sucks for bottom end with a 302. originally i thought i had an aode but i got looking at it and i have a tv cable and no harness so i assumed it is the aod.
Old Jun 27, 2009 | 06:26 AM
You do not lose the OD with the one-piece shaft, you merely lose the lockup feature. It still has four forward gears. Additionally some of the aftermarket valve bodies allow a WOT 3-4 upshift which the stock valve body will not allow.
Toy need to do some research. Check out Art Carr and Lentech for starters.
Old Jun 27, 2009 | 11:11 AM
Matts ford's Avatar
alright i'll look into. thanks
