33x15.50x15 on 12 wide rims
Old May 28, 2009 | 05:05 PM
DAsteve's Avatar
do you think a 33x15.50x15 tire on a 12 wide rim will clear a supercab 4X4 F150 with a 4" lift and 2in coil spacers????
Old May 28, 2009 | 09:52 PM
DAsteve's Avatar
come on.... anybody??????
Old May 28, 2009 | 09:54 PM
aswaff400's Avatar
most, if not all 4 inch lifts recommend 33x12.5's so you wont have any problems, hell you can even run 35's with very minor trimming
edit: i just noticed 33x15.5's, i'd say they'll fit... your front outer wheel bearings will hate you for it though... i have to replace mine at least once a year depending on how much i go 'wheeling
Old May 28, 2009 | 10:02 PM
DAsteve's Avatar
thanks but will the 15.50 wide tires rub at all???
Old May 28, 2009 | 10:39 PM
aswaff400's Avatar
yes, even 12.5's rub the rad arms, the 15's you may have to do some minor inner fender trimming so they dont rub
Old May 28, 2009 | 10:49 PM
DAsteve's Avatar
thank you...but with a 4" lift will it rub the outer part of the fender or bumper?
Old May 29, 2009 | 07:59 AM
aswaff400's Avatar
the fenders might if you hit a bump while turning, for the bumoer, all you have to do is space the bumper out about 2 inches... thats what i did cuz i didnt want to cut a brand new bumper, plus it leaves enough space to put a 8k lb winch behind the bumper... when the lift is new, it might not rub but as the springs and everything gets broken in, it may rub. mine started to rub after about 1000 miles (mostly highway)... if it does ru too much you could always put in a body lift
Old May 29, 2009 | 08:30 PM
DAsteve's Avatar
yea but wut if i get 2in coil spacers on top of the 4" lift.. and run 33x15.50x15 on a 12 wide... would they clear after the springs settling???
Edit:nvm goin with a 6in lift... hope that will clear 33x15.50x15 on a 12 wide that has a really wide offset... any input would be appreciated... thank you
Old May 31, 2009 | 02:59 AM
adrianspeeder's Avatar
Thats a wide freakin' tire. Actually can't recall seein' one in a 33. Goin' for the hotwheels look?
Adrianspeeder
Old May 31, 2009 | 09:44 AM
DAsteve's Avatar
Adrianspeeder
haha not quite... i think im goin with 33x13.50s now
Old May 31, 2009 | 06:47 PM
GTRider245's Avatar
DO NOT mix a lift kit and coil spacers.
Old Jun 1, 2009 | 04:32 PM
DAsteve's Avatar
can u explain???
Old Jun 1, 2009 | 11:33 PM
GTRider245's Avatar
Originally Posted by DAsteve
can u explain???
The 4 inch lift kit will come with drop brackets made for a 4 inch lift, not 4 inch springs plus a coil spacer. If you want 6 inches of lift, get a 6 inch lift with 6 inch drop brackets.
Old Jun 3, 2009 | 07:41 AM
DAsteve's Avatar
yea im goin with a 6in on 12 wides and 33x13.50x15
Old Jun 3, 2009 | 01:59 PM
GTRider245's Avatar
You will get the Hotwheels car look and they will rub at full turn lock.
