daytime running lights
Old May 26, 2009 | 10:32 PM
tfast150's Avatar
I just picked up a 97 F250 and its got DRLs (daytime running lights) how do i get rid of these?! i dont want to drive around with my park brake on...its a standard!!
Old May 27, 2009 | 12:01 AM
Steve83's Avatar
Why are you posting a question about a '97 in the PRE-97 forum???
Old May 27, 2009 | 06:25 AM
StrangeRanger's Avatar
Because 97 F250s are identical to the 96s.
It's not just a simple unplugging of the DRL module. There are some connections that will need to be made to complete the by-pass. The best advice I can offer is to get a copy of the EVTM for your truck and compare sections 85 and 97
Old May 27, 2009 | 11:22 AM
Steve83's Avatar
Duuuhhh...:o I missed the "250" part.
Unplug the DRL module & install the DRL jumper. The connector is below & inboard of the L headlight. You can access it by removing the grille.
Old May 27, 2009 | 11:48 AM
Is the DRL jumper a Ford part or is it a homemade set of splices that repair the missing connections?
Old May 27, 2009 | 04:41 PM
Steve83's Avatar
It's what Ford put in most (if not all) '94-96 US trucks. I think the DRL module was only used in Canadia.
Old May 27, 2009 | 09:40 PM
Matts ford's Avatar
how will the DRL's make you drive around with the parking brake on?
Old May 28, 2009 | 12:56 AM
Steve83's Avatar
Because most DRL systems (including the one in question) shut down when the e-brake is NOT fully released (first click).
Old May 28, 2009 | 03:28 AM
adrianspeeder's Avatar
Could be a LD250
Adrianspeeder
Old May 28, 2009 | 07:49 PM
Steve83's Avatar
Adrian
Aren't you supposed to be mopping bird crap off a runway somewhere? When you have a few minutes to spare, read the latest BS from 'that other BBS'...
Old May 31, 2009 | 12:29 AM
tfast150's Avatar
sweet thanx guys i found it all you have to do is unplug it! and you can reach it from underneath the truck!
Old May 31, 2009 | 02:53 AM
Originally Posted by Steve83
Adrian
Nope, scraped some off of a horizontal stab 65' up in the air though the other day. Mmmm, pidgin!
Good job on that humdinger there! Epic fail...
Adrianspeeder
Old May 31, 2009 | 06:51 PM
GTRider245's Avatar
Adrian
I missed that, but it said it would be lifted 2 months ago?
