gas tank pressurizing?
Old Jan 22, 2009 | 07:07 PM
FoMoCo1's Avatar
i have a 96 x-cab f-150, noticed after a drive today that my front filler neck area was leaking...checked it out and noticed that its coming from the cap area...when i tried to take the cap off i got alot of hissing and the gas really started to leak...
went to check the rear tank and got the same hissing but no leak
i dont use the front tank (pump bad) but i do use the rear
any help or direction would be great...thanks
Old Jan 22, 2009 | 07:12 PM
bigbronc's Avatar
Has the fuel level dropped in the rear tank, but went up in the front tank? If so, the rear pump is filling the front tank due to a bad check valve in the front tank fuel pump.
Old Jan 22, 2009 | 08:14 PM
FoMoCo1's Avatar
yep, just went and checked....the front tank (which i havent used in a year) is completely full....
what exactly do i need to do to correct this problem...thanks
Old Jan 22, 2009 | 08:57 PM
bigbronc's Avatar
There was an old recall that placed check valves on the fuel pumps to stop this. Can't remember the number for the recall. You could try and call a Ford dealer and see if someone in parts remembers the part numbers. I can try and research it a little. But, if you replace the front tank fuel pump with a new one from Ford, it will have an updated check valve installed in the pump. They are a little pricey, though. I would try and find the valves first. They have to go on both pumps.
