Grinding in 3rd gear only!
Old Jun 5, 2001 | 10:03 PM
redbeard's Avatar
Question Grinding in 3rd gear only!
I have a 95 5spd I6.Ever time I shift from 2nd into 3rd it grinds.If I tease it in 4th then go to 3rd it doesn't grind.Can I get this fixed?If so how much and what is causing it.
Old Jun 5, 2001 | 10:21 PM
fordby4's Avatar
Talking
My truck was doing that about 6 months ago. I could "get by", by moving the stick to the left side of third, if that makes any sense. Well, anyway, I took it into the shop a couple od days later, and they told me it was the shifting forks, worked fine ever since then. Hope this helps!
Old Jun 6, 2001 | 01:35 PM
Shadowhunter's Avatar
Post
I have a 96 F-150 302 that has recently started making a similar noise going into 3rd gear. I have been told (haven't verified yet) that it is the synchros (sp) not sure if that is the same as the shifting forks also going into 1st it grinds sometimes, but if I go to 2nd then to 1st it's okay. May have to try Fordby4's solution for 3rd. Good Luck, hope this helps some
Some days it's just not worth Gnawing through the leather straps
