Clutch Problem:(
I was driving yesterday, when I pushed the clutch in to shift to second, the pedal just stayed mashed down to the floor when I released my foot. So, I used my toe to pull the pedal back out. Now, it won't puch down AT ALL!! I had a buddy of mine tow me to a trusted local mechanic. Anybody have any idea of what I might be looking at?
-problem?
-how much?
-anything else?
I have a couple of theories, but there's much more experienced people than me out there. I'd appreciate ay input, thanks.
-problem?
-how much?
-anything else?
I'd say something might be wrong with the clutch master cylinder. Check the fluid also.
The truck:
Teal 1997 XLT flareside with 4.6L, auto tranny, electronic shift on the fly, 3.55LS and 4x4 ORP.
Performance mods:
Gen. 2 K&N FIPK
Superchip(removed until further notice)
True dual exhaust exiting out the back
2.5" pipe with 18" glasspacks and 18"x4" round chrome slash cut tips
Appearance:
White face gauges
Euro clear corners
01L headlights
Covercraft tonneau cover
Billet pedals
16" Modern© wheels
265/75r16 Wild Country Radial TXR tires
Factory tinted rear windows
Bug deflector
Euro clear corners
Sound system:
Clarion ADX5655z Double Din Cassette & CD
4 Pioneer TS-A6865 speakers
Other:
Bedliner
Bulldog keyless entry/remote start
n6260k@cs.com
<A HREF="http://www.f150world.com/v8speeddemon" TARGET=_blank>
</A>
The truck:
Performance mods:
Gen. 2 K&N FIPK
Appearance:
White face gauges
Euro clear corners
01L headlights
Billet pedals
16" Modern© wheels
Bug deflector
Euro clear corners
Sound system:
Other:
Bedliner
n6260k@cs.com
When you pulled the clutch back out with your foot was it really stiff or did it come right out? What year is your truck and how many miles does it have? My brother had some crazy things happen with his clutch and it turned out to be the linkage. Just my .02
1990 Ford F150 XLT Lariat 4x4
5spd
5.0L 302ci
K&N Filter Charger
Hedman Cat with MagnaFlow muffler
Tint
Rhino bed and undercoat lining
100 HC AudioArt Amp w/3 12" Impulse behind the seat
5spd
5.0L 302ci
K&N Filter Charger
Tint
Well, the mechanic called at about 12:00 noon. He said the clutch was bad, the slave cylinder and the throw-out bearing. I guess I should not have been so blind to the obvious...it's the original clutch with 130,000 miles. Altough, I never really did notice it start to slip. So far it's going to cost me $400...I think there using FORD parts. But, this is a really good mechanic, and he's given me very good benefits from his work before.
Oh, when I pulled the clutch back up, I couldn't get it to go back down worth anything! I was pushin' hard...it wouldn't go down! I probably shouldn't have pulled it back up, but it seemed like a good option at the time! Thanks for your help guys, maybe I even helped you guys out!
Fordby4
Fordby4
I have had a similar problem with my 1996 F-150. In my case it happened to be the Slave cylinder. am not sure of the year of your rig but on mine the slave is located inside the bellhousing
which is a real pain to get to. The part isn't that expensive to buy, it's just the time needed to replace it that's a bummer. Hope this helps.
--shadowhunter--
Some days it's just not worth Gnawing through the leather straps
which is a real pain to get to. The part isn't that expensive to buy, it's just the time needed to replace it that's a bummer. Hope this helps.--shadowhunter--
Yep, I expected the price to be high, I know clutches are expensive..plus labor. It would probably be cheaper to use "non-ford" parts, but I'm fine with it. ..Especially if it lasts another 130,000 miles
! Thanks for your help!
