post for Jimbello
I have a question about the temp. gauge that you changed a while back. Mine is inop and so I removed the gauge cluster to examine it. I don't see how changing just the temp gauge is possible. The back of the cluster seems to be one unit. It's covered with a circuit board made of thin flexible plastic. Does this sound like the one you have?
1995 F-150 XLT SC 4X4 shortbed blue & white 351 5.8 auto.
3.55 limited slip front AND back
JBA stainless steel silver ceramic coated headers
Bassani stainless steel performance Y-pipe & high flow cat
Gibson stainless steel swept-side exhaust (for towing torque)
K&N FIPK
Superchip
Edelbrock IAS shocks
31 x 10.5 BFG A/T K/O
K&N FIPK
Superchip
Hi, You can't change just the temp guage....Well you can but you have to buy the oil/temp compo so you might as well change both. It is real easy. It looks a lot more intimidating that it really is.
All you do is order the part, I paid I believe $100 for it. You "DON"T" have to remove the entire cluster. Just remove the clear plastic (FRONT)
lense that covers the cluster and the temp/oil guage assy pulls right out. Replace and put back together.
I did it last summer and it took maybe an hour or so. That's with also cleaning the cluster before putting it back together.
I looked throught the old threads from last year and cut some info I posted. Hope it helps ya....See below
Part # F8TZ-10883-BA TEMP GAUGE
Now, mine is a '96 but the dash is the same from 92-96
When you look for the part they are going to ask if you have a tach and and have the production date ready for them.
[This message has been edited by jimbello (edited 06-02-2001).]
Jimbello,
Thanks for the help I paid $80 for it from the dealer and have it installed. It was as easy as you said and it works great. Thanks again.
Jetter
K&N FIPK
Superchip
Jetter
K&N FIPK
Superchip
