need to wake engine up
Old May 12, 2001 | 01:08 PM
Donate54's Avatar
Post need to wake engine up
hey guys, im in need of advice. i need to wake my engine up, and im planning on rebuilding my engine. after i rebuild, im thinking of a good set of heads, cam and intake, but someone told me that i need to change my truck to a mass air intake system(???) or the engine won't respond to heads/cam/intake mods as good as it should. can anyone explain this to me? where can i find the pasrts i need? thank you very much for your help!
1989 F-150 XLT Lariat: 2WD 302 5spd[*]Performance Accessories 3" Body Lift[*]33x12.50.15 BFG A/T's on 15x10 AR Rims[*]Rancho Steering Stabilizer[*]Rancho RS 5000 Shocks[*]K&N Air Filter[*]Gutted Cats with Straight Pipes For Now...
Go Full Speed or Go Home!
Old May 15, 2001 | 06:55 PM
Fordman302's Avatar
Smile
You can usually find the Mass Air kit in Summit or Jegs. YOu can do those mods with your current set up, but you'd have to ask the people that you order all your parts from and see what they say.
I'd say go for a mild cam, and intake. I'd also port and polish your heads, and leave the heads alone, you can always add heads later on after a few mods. It will be a lot cheaper if you just port and polish them.
I'd also add a set of full length headers, and an exhaust.
Old May 16, 2001 | 02:41 AM
Fadex's Avatar
Post
Do the mass air conversion first. You will not get the results you want until the computer can adapt for more air flowing through the engine. Which is what a intake, cam, or almost any other modification will do. My .02.
'96 F-150 302
Hedman Hedders, Catco Cat., Gibson Super Truck, K&N F.I.P.K.
Old May 17, 2001 | 08:58 PM
murphydo's Avatar
Post
i saw you have a performance accessories 3" body lift. i was wondering how hard it was to install, are there any things that need to be adjusted or modified. email if you want, murphydo@shu.edu
Old May 17, 2001 | 10:41 PM
Donate54's Avatar
Post
murphydo,
the body lift was a very simple install. if you are going to attempt to install one, make sure you have some good jacks and a buddy to help ya out (4 hands work better than 2). it took a friend of mine and i about 4 hours to install mine, and that was taking our time and making sure all the bolts wer nice and tight. if you have access to air tools then use them, they will make the job much easier. good luck!
thanks for all the information guys! i got another question, whats a good price for an engine rebuild? im gonna start getting quotes from shops in my area and i want to know what a decent price would be. the engine has about 80,000 miles and i think it would benefit from a rebuild before i start with the mods. thanks a lot for the info guys!
[This message has been edited by Donate54 (edited 05-17-2001).]
Old May 20, 2001 | 02:38 PM
Fordman302's Avatar
Smile
while you are having it rebuilt have it bored out .030. I don't know if they included that. Then if you don't get new heads port an polish your ones. Add a mild cam, headers, MAS air, I'd do an intake. If it was me I'd make it carbeurated. Much easier to work on in my opinion.
