Hesitation when hitting the gas
Old Apr 23, 2001 | 03:58 PM
F150Jim's Avatar
Exclamation Hesitation when hitting the gas
I have a 94 F-150 with 83k miles on it. When I am at a complete stop and hit the gas the engine hesitates and seems to struggle for a bit, the lighter I touch the gas pedal the more it hesitates, it even stalled on me once in a fast food line when I just tapped it to move forward a bit. There is no other problems with the truck, it runs wonderful and I got it up to 75mph on the highway and it is smooth as can be. Is this anything serious? What can I do to correct the problem.
Old May 8, 2001 | 09:52 PM
beechkid's Avatar
25 Year Member
Cool
Check to make sure the EGR valve and vacume actuator is working, that's typically the problem. Also check the o2 sensor, they typically begin deteriorating at 50,000 miles.
Member: Never trust a person over 40 who drives a Chevy club
Flatheads ain't so bad!
Certified backyard mechanic I & II
Old May 9, 2001 | 01:52 PM
ENewman's Avatar
Post
I have a '94 and it would do the same thing, I fixed it by disconnecting the air hoses from the throttle body and spraying carburetor cleaner into each throttly body opening. When you do this leave the truck running and spray the cleaner in there really lightly so it doesn't kill the motor. If you want it to work even better take the cover off of the throttle linkage and rev up the motor with one hand and spray the cleaner into the throttle body with the other hand. The problem is carbon builds up in the throttle body after awhile...continue spraying out the throttle body until you don't notice the hesitation anymore. It works...trust me.
1994 F-150 XL 4x4
I-6 300ci 88K miles
Auto Transmisson
Standard Cab, Long Bed
3.55 Limited Slip
20% Window Tint
Kenwood eXcelon X715 CD Player
Diamond Plated Delta Champion Toolbox
DeeZee Bright-Tread Bedside covers
Old May 16, 2001 | 12:28 AM
thumpin150's Avatar
Unhappy
I ahve a 92 f150 and I have had maybe the most problems, I can recomend a few things.
The Idle air motor sometimes gets carbon and ruins it, and it doesn't work properly.
Also the o2 sensor, if not already changed.
The map sensor, that was a big problem for me. also check ALL the vacuum lines and check valves, high milage engines have alot of carbon. Oh and yes, check vacuum canisters for leaks. hope this helps,
Jesse
Anyone out there with a 92-96 f150, please share mods, thanx
