302 SWAP FOR CARBURETOR 460
Old May 10, 2001 | 10:36 PM
dvldog458's Avatar
Question 302 SWAP FOR CARBURETOR 460
Hey guys.
I'm swapping my 302 EFI/4wd E4OD trans out of my 1991 F-250 for a 460 big block/C6 trans out of a 1983 f-250.
Any suggestions for installation would help.
If you need any after market parts for a 302/E4Od trans checkout my home page.All engine and trans parts are going!
http://hometown.aol.com/dvldog458/myhomepage/auto.html
Jerry D.
[This message has been edited by dvldog458 (edited 05-10-2001).]
Old May 10, 2001 | 11:55 PM
redlariet's Avatar
Post
I think you will need the motor mount brackets and rear cross member from the older truck + replumb the fuel system + disable the computer stuff if the 83 does not have a computer / check engine bulb & eec4 module should be all you need to take out. You will have to remove the in-tank fuel pump and the high pressure pump on the frame rail behind the driver's seat and run a suction line from the tank to the engine fuel pump. I hope that gets you started. It should be a runner when it's done.
97 Lariet-sc-4.6-4x off road-auto-3.55 LS-
superchip-Airraid-Perma-cool electric fan & controller
Old May 11, 2001 | 10:06 PM
dvldog458's Avatar
Post
Instead of repluming the fuel system,can i just use a fuel pressure regulator and set it around 6psi?
[This message has been edited by dvldog458 (edited 05-11-2001).]
Old May 11, 2001 | 10:40 PM
redlariet's Avatar
Post
The hi pressure pump needs good EEC-IV signal to run. you might be able to remove it & patch in a hose to the engine pump.
