Changed gears and speedo hasn't changed
Old Aug 15, 2000 | 10:23 AM
1ToughTruck's Avatar
Post Changed gears and speedo hasn't changed
I recently went from 3.31 gears to 4.10 gears and was expecting to have to change my speedo gears. I checked it with my GPS and the speedometer is correct, as it was before. Is this possible with my year truck? I also expected a big change in power, but there wasn't that much, but I'd do it again. It seems to pull my camper better.
1995 F-150, 302, 4x4, auto, superchip.
P265/75R/15 tires
Old Aug 15, 2000 | 02:15 PM
tim_1911's Avatar
Post
I went from 3.08 to 3.73 on my 97 4.2 5-speed. There was no doubting the change pulling out of the shop. Big difference, the truck climbed in RPM's much faster and jumped off the line. You should notice a higher RPM at highway speeds, too.
1994 F150 XLT Supercab, 302 V8, E4OD, MSD 5200, Flowmaster 40 series, K&N FIPK
Old Aug 15, 2000 | 09:34 PM
StrangeRanger's Avatar
Post
Sounds like you've got the vehicle speed sensor in the rear end. Cool, huh? No gears to mess with. Is your speedo/odo digital?
Old Aug 16, 2000 | 05:20 PM
max mitchell's Avatar
Question
The gear change that you described (without other changes; like tires), should be very noticeable. Quickness, highway rpms, etc. Did you change them, or actually see someone do this? Sure sounds unusual!
2000 F-150 XL,RC,LB,5.4,4R70W,3.55LS,
Class III tow/Payload #3/Convenience pkgs.,
4-wheel disc/ABS,Chestnut/Parchment 40/60,
Ford bedliner & gas/wheel/spare locks,
3" cold air box modification, Superchip,
Dynomax ultra-flow welded 3" cat-back,
3" exit Y-pipe, Hellwig rear anti-sway bar.
Old Aug 16, 2000 | 11:05 PM
Post
I can tell some difference but it's not dramatic. I know the guy that did the gear change and I trust him, I can hear a faint whine of the new gears in the rear. I had thought about counting the gears on the new ring gear just to be sure, but I don't remember the formula. I believe the 302 is just under-powered. The superchip helped too, but again, nothing that great.
Old Aug 18, 2000 | 07:02 AM
Rich's Avatar
Post
Toughtruck,
Send me your email address, and I'll send you the formula for setting your speedo to make sure it is correct. I used it when I changed my tire size, and it was correct.
Rich
rdtect@snet.net
