Oil in the vacuum lines
I've been having spark know troubles, went to replace the MAP sensor, found oil in the vacuum line. Possible sludge problem causing the oil not to return to the pan, and causing an overflow into the vacuum lines. I'm going to pull the valve cover to see if the valves are sludged, any other suggestions would be great.
1994 F-150 4X4 Regular Cab, 302 EFI, 5 spd. K&N Filter, Gibson Super Truck Split Rear Exhaust
Pastmaster,
I got a new knock sensor, I having trouble locating where the old one is. I am going to replace it no matter what. Let me know where this is located.
