93 - 2WD Ball Joints
Old Apr 4, 2000 | 05:58 PM
Jetmech's Avatar
Post 93 - 2WD Ball Joints
I found my upper R/H joint is a little worn. So I plan to replace them all saturday. I've never done them before and was hoping to get any tips if there are any I should know about.
In my "Haynes" repair manual it states "Mark the orientation of the upper balljoint camber/caster adjuster sleeve (located in axle assembly) for proper positioning upon reassembly."
however the only figure only shows a "camber adapter". Are these one in the same????
If they are the same, i dont see how you can re-install them wrong ???? (unless you switched left and right)
Thanks for any tips / thoughts
93F150 4.9, 2WD, spindle mounted joints
Old Apr 6, 2000 | 12:17 AM
nailer's Avatar
Post
Jetmech, Had mine replaced a year ago, and as much as I prefer doing my own service, I sent it out for the ball joints. If I rember, was about $300.00 total. Figure $60.00 for alignment, $100.00 for parts, and the rest labor. At $59.00 per hour, figured it was a good deal. Front ends have always made me hesitate. Nothing worse than having your ride all apart in the driveway on Sunday and you need some small part (when the stores are closed).
Good Luck,
-----nailer-----
ON ORDER: 2000 F250 SD SC XLT V-10 SB With all the goodies! (Due Mid-April)
CURRENT: 1993 F150 SC XLT 5.0L V-8 with 165,000 miles, (a new x-mission), and lots of great memories!
Old Apr 16, 2000 | 06:56 PM
Jason Zaluski's Avatar
Post
Hey, I just installed a drop kit this weekend, and the front is something you can do. Once the wheel is off, you have to remove a pin, and a castle nut. Take the castle nut off the front tierod also, and use a ball joint tool to pull it. Then mark the ecentric spacer on the top, and pry the spindle down. Watch out cuz it'll drop fast. Once it's down, you're good to go. E-mail me if you have any q's
1995 F-150 Regular Cab Flareside w/ 302 V8... Mods: Mass Air, K&N FIPK, Dual Exhaust (no mufflers), Lund Premier Tonneau Cover, Motorsports 9mm Plug Wires, full JL/Kicker/Pioneer system
The F-150 Resource Guide
The F-150 Resource Guide-- a site dedicated to 1987 through 1996 F-series trucks.
