Wind noise from driver door
Old Mar 12, 2000 | 10:07 AM
4x4Ranger's Avatar
Post Wind noise from driver door
On my 93, my driver door leaks air bad. Its too the point where if you look up at it at certain angles you can see outside through the door seals. Its like the door isn't closing all the way, but it is closed all the way. If I replaced the door seals would this help?? Anyone else have this problem?
1994 Ford Ranger 4x4 4.0L, K&N, Superchip, 63mm T-body
1993 F150 Ext. cab 4.9L 5spd 4x4
Old Mar 12, 2000 | 11:06 AM
Pastmaster's Avatar
Post
Both of mine are that way...I ended up buying some more insulation, you know the stickon strip? I put it on, and its helped alot.
Old Mar 12, 2000 | 02:24 PM
4x4Ranger's Avatar
Question
I've never heard of that stickon strip. What is it and where can I get it??
Old Mar 12, 2000 | 06:24 PM
Pastmaster's Avatar
Post
You can buy it anywhere, like Walmart or whatever. I think its supposed to be used for house windows. Its a foam stickon.
