95 F150 Tranny Question
I have a 95 F150(5.8) with a towing package. I was recently towing an aluminum two place snowmobile trailer and noticed that it was searching for a gear running at about 55-60 on flat land(interstate). Is it possible that the tranny is going or do I need a chip that can change the shift points. Any suggestions would be greatly appreciated. Thanks in advance!
Marc
Marc
Just turn OD off when that starts happening. Regular transmission service (fluid & filter change) is essential to their longevity. If you haven't changed the fluid in a while, you might try that first.
Thanks for the info, I have changed the fluid and filter. When I was off the interstate on 2 lane highways, I found that with OD off, it searched for a gear around 45, but it was slightly hilly. Just thought it was odd, since it is a 351 w/towing pckg. Any thoughts would be great.
Marc
Marc
I can remember my dads 1990 F-150 equipped with a 302/Aod. That was the last of the Aods for us until my 89. It wouldn't go into 1st gear, and hardshifted into later gears. I would say that a chip wouldn't hurt at all, or maybe all you need is a shiftkit. B&M makes a shift kit for $40.
I think I have the same tranny as you do. I also pull, I was having hard shifts with mine. It didn't really search for a gear it would just shift hard when pulling. My brother-in-law is a Ford mech at the local dealership. He informed me that a TSB (I don't know which one)instructed the use of synthetic fluid in the tranny if towing is involved. I had this done and have been pleased with the results.
This may not be the same issue ,but it is a start. BTW I also have the two package.
Mike J.
1997 F-250 HD (old style) Supercab 4x4 w/ 7.5l 460. Jacobs Electronics Ceramic 2000 plug wires, Side-gapped Autolite plugs,Synthetic Oil, K&N air filter, Tonneau cover and bedliner are my only upgrades so far.
Mike J.
What rear end ratio do you have? That may be an influencing factor?My folks have 2 chevys a 96 sububan and a 98 c/k. the suburban has a 3:42 LS axle while the c/k has a 3:73 ls axle. There is a VERY noticable difference in shifting points on hills and while pulling. The c/k usually never shifts going up the flint hills here in Kansas but the suburban can't stop.
