Howling front wheel
Old Oct 11, 1999 | 05:24 AM
Chris Sonego's Avatar
Post Howling front wheel
About a month ago, I took my 96 4x4 into the dealer when started howling at low speeds. It only did this on the driver's side front. When I got it back, the mechanic said it was just to rubber seals that needed lubricating. Well, after another road trip, it started howling again. This time, I took it apart and found what the mechanic said. Behind the brake rotor, there is two rubber seals. One is stationary and the other rides on top of it and rotates. I lubricated it and the noise went away. It's back again. Has anyone had this problem? Is this caused from something else? Do I need to replace the rubber seals?
Thanks,
Chris
96 F 150 SC 4x4, 5.0, All Black, Custom Cat Back 3 Chamber Flowmaster with dual outs and 3.5" tips, Superchip, and K&N Filter
Old Oct 19, 1999 | 09:14 AM
BillyD's Avatar
Cool
I have a 95 and it did the same thing to me it turned out to be my wheel bearings had them replaced and it went away. Hope this helps Billy
95 F-150
91 5.0 LX 12.20@123mph
