Blower motor replacement?
Old Sep 10, 2008 | 04:50 PM
High Mileage's Avatar
Apologies for the cross-post. I posted this in the HVAC section as well, but have a feeling that I may get more of a response here...
New member here, and new F150 owner. Just bought a 96 F150 standard cab w/ 344k miles on it, and it currently does not blow air through any of the vents (or floor/dash). I'm assuming that the blower motor has died, because the compressor still kicks on when I switch the system to A/C. Can someone give me a general idea of where I'll find the old blower motor so I can stick a new one in there?
Also, is this the only part I need? http://cgi.ebay.com/ebaymotors/92-93...spagenameZWD1V
Thanks in advance!
Old Sep 10, 2008 | 09:03 PM
subford's Avatar
Have you checked fuse #1?
The compressors clutch will work with this fuse bad as the clutch uses a different fuse (#6).
The blower is located on the RH side of the firewall in the engine compartment.
