Wondering if I can remove the cats and computer
Old Nov 14, 2007 | 02:40 PM
Radio's Avatar
My computer doesn't show any problem codes.
Old Nov 14, 2007 | 03:24 PM
selbona's Avatar
Originally Posted by Radio
I gutted my cats on my 95 5.0 and had some serious fuel efficiency increases just clicky on my signature.
I read your post. I can't figure out what your mileage actually is now. I think we've got the same set up. 302, 5 spd. I've still got the stock 3.55 ratio. What do you think you get per gallon, just normal driving around. Also, have you got the stock manifolds still on or headers?
Old Nov 14, 2007 | 06:16 PM
StrangeRanger's Avatar
Originally Posted by selbona
Alright, so I'm stuck with the EFI and the computer unless I want to completley gut my truck and start over. So, if I cut the cats off, does anyone know what will happen to the sensor readings in the computer? I guess it's going to throw a code, but what, if anything, can I do to bypass it?
Only the 96-up trucks have a post cat sensor to monitor cat function. Yours does not. You need to think about what you're going to do with the smog pump though.
If your cats are functioning properly, do not expect to see any MPG gains by removing them. If they are clogged, that's a different matter.
Old Nov 14, 2007 | 08:13 PM
ccmac's Avatar
I know if you gut the cats you need a fake o2 sensor, but i'm having a hard time finding where to buy one. I found plans on how to make one, but im not very good with things like that.
Old Nov 14, 2007 | 11:09 PM
Not true.
With or without cats, the EFI system requires that ALL upstream HEGO sensors remain functional. On 96-up vehicles with OBD-II there is a downstream HEGO sensor between the cats and the muffler. If you gut the cats on an OBD-II vehicle you must install a MIL-eliminator on the downstream sensor. The upstream sensors MUST remain functional regardless of OBD-II or not.
Old Nov 14, 2007 | 11:25 PM
MGDfan's Avatar
Originally Posted by StrangeRanger
Not true.
110% correct. No active upstream O2's = no A/F ratio closed loop control = truck no workie
Old Nov 14, 2007 | 11:48 PM
Truck workie with no closed loop but it runs nasty rich.
Old Nov 14, 2007 | 11:55 PM
MGDfan's Avatar
Dat to me is no workie
Old Nov 15, 2007 | 10:38 PM
ccmac's Avatar
I've crawled, and looked all over my truck, but I cannot find a o2 sensor after the cat on my 96 300. I'm 99.9% shure there is not one, but i have been wrong before.
Old Nov 15, 2007 | 11:14 PM
IIRC what a stock exhaust looked like, look at the pipe about a foot in front of the muffler. You should also have one in each exhaust manifold
Old Nov 20, 2007 | 02:46 AM
Radio's Avatar
15.5 city and 25 Highway
stock manifolds
3.31 ratio differential
Old Jun 9, 2012 | 01:20 AM
nickel_work87's Avatar
There will be no problems if you cut the cats off. The o2 sensor is before the cats so you don't have to worry about that. The later model trucks have one after the cat to see if they are working right.
Old Jun 9, 2012 | 01:53 AM
I doubt they see your post, that was 5 years ago.
Old Jun 9, 2012 | 09:32 AM
adrianspeeder's Avatar
Holy stupid thread from the dead!
Adrianspeeder
Old Jun 9, 2012 | 11:37 PM
Yea i know guys i just see an thread and comment if i think i can help. Plus it gives me something to do at night.
