brake fluid
Old Oct 27, 2007 | 05:16 PM
nintey4f150's Avatar
brake fluid
my 94 f150 was low on brake fluid the other day so i filled it up and about a week later its low again..i cant seem to find or notice any leaks...any help would be nice
Old Oct 27, 2007 | 06:46 PM
F151's Avatar
I'm sure it will show up..... double check all the soft lines. Also behind the booster and master cylinder.
Old Oct 27, 2007 | 10:21 PM
skate1678's Avatar
yeah see if any paint is starting to peal on ur booster below where the master goes into it
Old Oct 27, 2007 | 10:23 PM
the 89's Avatar
keep an eye on the back side of your brake drum and fluid getting slung on your rear tires. a rear brake cylinder could be leaking and its sort of hard to locate the leak
Old Oct 28, 2007 | 12:00 AM
Steve83's Avatar
Where are you? In a salt region? Crawl under & examine the brake lines. Click my black Bronco below & look in the Brakes & Hubs album. Your truck has RABS.
Old Nov 2, 2007 | 11:00 PM
red-truck's Avatar
Check soon
Check the bent steel brake line behind your left front wheel. I believe it goes under the plastic innerfender. They tend to rust through here. My 94 blew while pulling a trailer. My dad has a 95 and his did the same thing about a month ago. He was ready to leave his driveway with a load of cattle and lost his brakes.
