is this possible
Old Oct 17, 2007 | 10:16 PM
nintey4f150's Avatar
is this possible
am i able to use a guage cluster from a 93 lightning in my 94 f150
Old Oct 17, 2007 | 11:29 PM
GTRider245's Avatar
The dash is exactly the same.
Old Oct 18, 2007 | 12:29 PM
yea i know that but the speedo goes to 120 in a lightning and only 90 in a f150 i dont know if thta matters
Old Oct 19, 2007 | 01:47 AM
Steve83's Avatar
The speedo isn't the problem - it's the airbag. You can't mix '92-93 clusters with '94-96 unless you're prepared to do some rewiring.
But you CAN swap JUST the speedos with no problems. At worst, you'll just have to calibrate the PSOM. While you're in there, you might want to add a low fuel light &/or make the oil pressure gauge actually work.
Old Oct 19, 2007 | 02:48 AM
usedtodrivechev's Avatar
Originally Posted by Steve83
add a low fuel light[/URL] &/or make the oil pressure gauge actually work.
What do you mean by the oil pressure guage not working?
Old Oct 19, 2007 | 09:46 AM
Steve83's Avatar
Old Oct 20, 2007 | 12:49 PM
i always wondered why it doesn't move around like my old gm's did. i just decided not to mess with it since everything seems to run fine.
