1996 Gas Tank Size
Old Jul 31, 2007 | 04:06 PM
jodiewhite's Avatar
Question 1996 Gas Tank Size
Just got a '96 Eddie Bauer, 4wd, Shortbed,with the 4.9 I'm liking it so far, but this thing sure doesn't get very far. At 14 mpg, I need to fill up around 200 miles. Do these all have small tanks or has mine been changed? And what's the best way to haul more gas, swap out the tank for a bigger one, or put one under the toolbox?
Thanks,
Jodie
Colorado, USA
Old Jul 31, 2007 | 06:36 PM
StrangeRanger's Avatar
A 4WD regular cab short bed has a single 18.2 gallon tank
If you want to give up the under-bed storage of the spare tire, you could fit a Bronco tank which is 32 gallons
Old Aug 1, 2007 | 07:54 AM
jodiewhite's Avatar
Perfect, is that from a '96 also? Or is there a range I can look for?
Old Aug 1, 2007 | 12:21 PM
I'm sure there's a range but IDK what it is. The junkyard of your choice should have a crossover list
Old Aug 5, 2007 | 02:08 AM
Steve83's Avatar
'90-96 Bronco gas tanks will fit easily, but you'll need the Bronco tank skidplate.
Click the black Bronco in my signature & look in the EFI Fuel Pump album. It shows how the tank is mounted.
