Electrical Problem? Help!
Old Jun 23, 2007 | 12:37 PM
94f1504.9's Avatar
on my f150 my abs light turns off after start up then turns back on in about 5 seconds then stays on constantly, i have no break lights, third brake light or turn signals. this all started as soon as i took out the the flasher under the dash to borrow it so i could ride my motorcycle. i have no blown fuses.
any help is much appreciated thanks.
Old Jun 23, 2007 | 09:45 PM
Bruce R Leech's Avatar
put the flasher back in and see what it dose.
Bruce
Old Jun 24, 2007 | 07:52 PM
94f1504.9's Avatar
Update!
yes, the first thing i did was put the flasher back in, ive replaced the bulbs in the tail lights, ive checked every fuse and relay on the truck, i put a new ground from the battery to the engine and the abs light goes off now but i still have no brake lights or turn signals, i have tail lights when the headlights are on. i would really appreciate the help as soon as possable as this being my daily driver.
Old Jun 25, 2007 | 08:38 PM
94f1504.9's Avatar
i had a stupid moment, well, actually my whole day was a stupid moment. my hazzards were switched on and they havent worked since i bought the truck. and it wasnt allowing the brake lights or the turn signals to work.
Old Jun 25, 2007 | 09:40 PM
hockeyfanjeff's Avatar
funny you mention that. i just had that happen yesterday. hazzards were clicked on but were not flashing. had a friend pull me over and tell me my brake lights weren't working
Old Jun 27, 2007 | 02:15 PM
Steve83's Avatar
The hazard flasher is hidden on the BACK of the fuse block, directly behind the turn flasher, and it's a PITA to install correctly because you can't see the terminals as you're stabbing it in.
