Transfer Case
Transfer Case
Hey!
1991 F150 4x4 302.
Recently my Tcase has been making a whiny noise when I put it in drive while in 2 high. It gets really loud when in 4h. Kind of like a "whiny moan" just long enough to enage in Drive. It doesn't do it while i'm driving though.
Is it dying? How long to I have? and Is it expensive?
Thanks!
1991 F150 4x4 302.
Thanks!
it could be dying when did you service it last? what dose it sound like in 4 wheel low? what type of oil are you using in it?
is it a push button shift or do you shift it with a lever on the floor
Bruce
Bruce
I didn't try 4 low. It sounds bad in 2h and worse in 4h. I don't do my own work on it, I'm guessing the shop I take it too would have looked at it last service time...
It has a floor shifter.
are you sure the noise is coming from the transfer case or could it be the drive shaft or differential?
Bruce
There are fill and drain plugs on the rear face of the case. Fill it till the lube is even with the upper (i.e. fill) plug. Considering you're having problems, you might want to drain the case and take a look at what else comes out then refill it. It takes 2 quarts of Mercon ATF so we're not talking about huge sums of money..
Thanks for all the help guys!
Is it possible to disconnect the tcase and turn my truck into a 2wd for now untill I have money to fix it?
What do you mean by not practical?
I need this truck for work everyday and I'm kinda broke right now.
Bruce
Allright my truck is in the next town over so I need to know what tools I need to drain and check the fluid level. When I had a look it looked like a strange opening on the fill/drain hole
Allright, the fillar plug was stripped but I got it off after yelling at it. The fluid was full and good looking. I'm booking it in the shop as I type this. Time to let some one else deal with it!
