Acceleration problems
Old May 20, 2007 | 10:13 PM
JmotoCRoss9's Avatar
My 95 150 seems to bog a little when i get on it. Any fixes to this bog issue chips, pipes?
Old May 21, 2007 | 12:26 AM
cavinandpavin's Avatar
motor? trans? any mods so far?this info will help to point you in the right direction
Old May 26, 2007 | 04:28 PM
jahwarrior1423's Avatar
misfire
Old May 26, 2007 | 08:18 PM
F151's Avatar
Could be any number of things. Start with the cheap/free stuff.....clean MAF and TB and intake, change fuel filter and test pressure, and work towards the more expensive stuff......O2 sensors, TPS, and so on.
Old May 28, 2007 | 01:03 AM
Steve83's Avatar
Good regular MAINTENANCE.
Old May 28, 2007 | 08:12 PM
RaWarrior's Avatar
Chips and pipes are to improve a well running engine, not cover up one that isn't. Go with the most basic things first. A dirty air filter will cause bogging, as will a plugged fuel filter. Run a good fuel system cleaner, I like K-100 or Seafoam, had results with both.
