E40d?
Old May 17, 2007 | 08:54 PM
Mr Kleen's Avatar
Question E40d?
How can I tell if I have an E40D transmission?
Old May 17, 2007 | 10:57 PM
cavinandpavin's Avatar
in the tranny section there is a break down of the codes for what tranny you have. the code is in the door jamb.bottom left of the sticker if i remember right.
Old May 17, 2007 | 11:27 PM
StrangeRanger's Avatar
In a 96 if you have a 300 or a 351 you have an E4OD; if you have a 302 it could be either an E4OD or a 4R70W. Look at the vehicle ID sticker on the door jamb. Trans code E = E4OD; U = 4R70W
Old May 21, 2007 | 02:48 PM
Mr Kleen's Avatar
4r70w
OK looks like I have this tranny. Is that bad? Truck has 145k miles on it currently and is my daily driver.
Old May 21, 2007 | 05:40 PM
RaWarrior's Avatar
Why would that be bad? E4OD is a bit "tougher" built and I think rated for more ?torque, but the 4r70w is just fine too. Neither one is "bad". The C5 is the only "bad" transmission to be found in Fords, and that's because it is a French piece 'o crap.
Old May 22, 2007 | 08:30 AM
signmaster's Avatar
Nothing wrong with the 4R70W unless you're going to add a lot of power to the stock transmission. Do a search in the transmissions forum, there is a lot of good scoop on some common concerns.
Old May 31, 2007 | 03:01 AM
Mr Kleen's Avatar
I just dont hear much about the 4R70W is all, everyone just talks about the E40D and how good they are so I assumed that I didn't have one that will last. Currently the 302 has a Hypertech programmer added and a drop in K&N filter. I'm not planning on putting a lot more power to it, probably just a Flowmaster exhaust system with Maggie muffler, and a K&N intake. It has enough power for me. I don't really know what else there is to do to it to boost power.
Old May 31, 2007 | 09:27 AM
Bruce R Leech's Avatar
before you do anything else do a flush and filter/fluid change. allot of times this will straiten out any problems. also put a big cooler on it.
Bruce
Old May 31, 2007 | 08:38 PM
And an external filter.
Old Jun 5, 2007 | 07:13 PM
frogallen's Avatar
This was written by an engineer at Ford. He knows his stuff.
http://www.tccoa.com/articles/tranny...on/index.shtml
Rodney
