Odd shifting issue
Old May 15, 2007 | 04:07 PM
Chris Mapp's Avatar
Odd shifting issue
I have a 1989 F150 with a 5.0L engine with 85,000 miles on it. As far as I know, I have the AOD transmission. I've noticed that when I slow down to go around a turn, then speed back up, my truck seems to shudder quite a bit, almost as if it shifted to too low of a gear. Is this what's referred to as converter chatter, or could I be looking at another problem?
Old May 15, 2007 | 04:39 PM
Bruce R Leech's Avatar
it is hard to say with out driving it. when was the last time you did a service on the trainsmition, and what did you do?
Bruce
Old May 15, 2007 | 05:47 PM
Chris Mapp's Avatar
It has been at least 9 months since the last service (about when I bought it). As far as I know, the filter and fluid were changed and that was all.
Old May 16, 2007 | 12:08 AM
Steve83's Avatar
That could be from several things; not just the trans.
Wheel bearings
Tie rods
U-joints
Rear axle
Steering box
Tires
Lug nuts
Suspension bushings
Get a pro trans technician to test drive it with you.
