Airbag code 94 f150?
Old May 10, 2007 | 12:34 PM
ShorgasmIII's Avatar
this is itermitent. doesnt do it everytime i start the truck, but the airbag light flashes 3,pause, 2. anyone know? i searched online and cant find out
Old May 10, 2007 | 11:36 PM
OAC'04 Wildcat's Avatar
I had that, and then it went to everytime i started the truck. Means high resistance on the circuit. On mine it turned out to be that the clock spring was shot. At the dealer it's roughly a $160 dollar part, kinda tough to swallow for a stupid flashing light given that i've not had any problems with the system or accidents in the 10 yrs my dad had the truck nor the 4 i've had it.
Old May 11, 2007 | 07:01 AM
adrianspeeder's Avatar
— No Air Bag Indicator — Inoperative Indicator Circuit or No Battery Positive Voltage to Air Bag Diagnostic Monitor
— Continuous Air Bag Indicator — Air Bag Diagnostic Monitor Disconnected or Inoperative
12 Low Battery Voltage
13 Air Bag Circuit Shorted to Ground
14 Front Air Bag Sensor and Bracket Circuit Shorted to Ground
21 Rear Air Bag Sensor and Bracket Not Mounted to Vehicle Properly
22 Rear Air Bag Sensor and Bracket Output Circuit Shorted to Battery Voltage
23 Rear Air Bag Sensor and Bracket Circuit Input Feed/Return Circuit Open
24 Rear Air Bag Sensor and Bracket Output Feed/Return Circuit Open
32 Driver Side Air Bag Circuit High Resistance or Open
34 Driver Side Air Bag Circuit Low Resistance or Shorted
41 RH Front Air Bag Sensor and Bracket Feed/Return Circuit Open
42 LH Front Air Bag Sensor and Bracket Feed/Return Circuit Open
44 RH Front Air Bag Sensor and Bracket Not Mounted to Vehicle Properly
45 LH Front Air Bag Sensor and Bracket Not Mounted to Vehicle Properly
51 Air Bag Diagnostic Monitor Internal Thermal Fuse — Fuse Blown Due to Intermittent Short to Ground
52 Backup Power Supply — Voltage Boost Fault
53 Front Air Bag Sensor and Bracket Circuits Resistance to Ground or Air Bag Diagnostic Monitor Fault
— Rapid Continuous Flashing of Air Bag Indicator (No Fault Code) All Primary Air Bag Sensors Disconnected
Old May 11, 2007 | 12:58 PM
Steve83's Avatar
Old Jun 18, 2007 | 05:54 PM
longbeard's Avatar
Mine started that right after I took it in for the cruise control recall, could that have caused it?
Old Jun 27, 2007 | 01:54 PM
Steve83's Avatar
No. The cruise recall can't cause any problems - it can make some existing problems appear, but it can't create any. The work that is done for the recall is LESS invasive than changing a light bulb. You can read the full text of the recall by clicking the black Bronco in my signature, scrolling down to the TSB/FSA album, & then finding that recall (FSA).
Old Jul 4, 2007 | 09:06 AM
longbeard's Avatar
I have also found out my horn doesn't work, and neither does my cruise controll.
Old Jul 8, 2007 | 02:05 AM
Steve83's Avatar
Click the tan CV in my signature & look in the Steering Column album - you need a clock spring.
Old Apr 16, 2012 | 01:38 PM
Nerys's Avatar
Thanks for posting the codes.
Got a code 44 - so is there a tutorial or something so I can find out where these sensors are what they look like and how to mess with them?
Old Apr 17, 2012 | 08:57 PM
Howdy and welcome. Good on ya for searching, now post what year and truck you have in your signature.
Adrianspeeder
Old Apr 17, 2012 | 10:48 PM
Nerys's Avatar
Thanks its a 94 XLT single cab.
I answer a lot of "forum questions" in my areas of expertise so I know whats its like to answer the same question again and again :-) I don't mind but I know how it can grate on people when users don't even try to search :-)
will get around to posting an intro when time allows. we LOVE the truck. got it essentially for free. we like ford trucks.
we have burned through 4 E150 cargo vans and when I say burned I mean it. all but one had over 400,000 miles one of those we think might have busted 500k (not sure speedo did not work for some time!!) the all but one had 360k on the ticker :-)
they were useless as vehicles anymore with gas prices the way they are we stop driving them years ago. we scrapped them and use the proceeds to buy the 95 F150 XLT.
really is a nice looking truck. just needs a little bit here and their and I would even call it a looker!!
I also have a 94 E150 Club Wagon. if money were no object its the ONLY vehicle I would drive. it is "BAR NONE" the single most comfortable vehicle to drive I have ever driven in my life.
Mercedes. Rolls Royce. Lincolns you name them they don't hold a candle to my Clubwagon when it comes to "driver comfort" for us big tall heavy critters (6'4" 400 pounds)
alas it gets driven maybe twice a year now and now and then to tow the camper or boat. the club did NOT switch over to E10 very nicely (went from 19-21mpg to 12-15 mpg) but its my baby. It would have to fall apart to pieces for me to get rid of it.
