Rear end oil change
Rear end oil change
I am planning on doing a rear diff fluid change on my truck when i get paid, well i found out the diff cover gasket is only 4 dollars. but i dont know the type of fluid and how much to use. Can anyone help me with this?
5.5 pints of 75W90. Do yourself a favor and use a synthethic. It will run much cooler.
If you have a Trac-Lok LSD, you need toeither use a lube which has the friction modifiers in it or add 4oz. of friction modifier
