Fuel Pump
Old Apr 19, 2007 | 08:28 PM
beaverbanker's Avatar
Fuel Pump
Whats the difference between the (92 302 4x4) 16 gallon pump & the 19 gallon.
Because i picked up a used pump. The new pump sits lower in the tank then my old one(doesn't fit) Does that mean they gave me the 19 gallon instead of the 16 gallon pump?
Old Apr 19, 2007 | 08:43 PM
I bent it less then a half inch and it fit. so im going to go with it,
Old Apr 19, 2007 | 09:06 PM
Also which line is the return & pressure, i find it had to tell from steves diagram
Old Apr 19, 2007 | 10:32 PM
Steve83's Avatar
Look where they connect to the fuel rail. The one that dumps straight into the injector rail is the pressure side; the one that's routed to the pressure regulator is the return. Then just follow that color to the tank.
