Fuel Pump
Old Apr 8, 2007 | 04:16 PM
beaverbanker's Avatar
Fuel Pump
My 92 f150 302 is near impossible to start. I tracked it down using the haynes manual. To a faulty fuel pump. With the fuel pump running non stop at KOEO via jumper to ground. It takes about 40sec to climb to 20psi then tops the regulator test proves fine and i replaced the fuel filter to be sure. Im going buy a new pump but how long should it take to climb to 35-45 psi. Also i home made my gauge, I took the valve out the stem on the rail, but a hose on the stem ran it to my gauge that had a nipple on the end. This would read the pressure accurately correct?
Old Apr 8, 2007 | 04:50 PM
89Lariat's Avatar
It should be at full pressure engine off once the "whirrr" noise stops, and to full running pressure once the engine is running. If you want, get an actual guage and see what it reads.
Old Apr 9, 2007 | 12:09 PM
Steve83's Avatar
...how long should it take to climb to 35-45 psi.
0 sec. By the time you get the pump powered up, it should be at operating pressure. Did you look thru the EFI Fuel Pump album in my signature link?
Old Apr 9, 2007 | 02:40 PM
Yah, I had a problem with the pump, sticking back in the winter. So ill just get one from a good yard i know. Should fix it all.
Old Apr 9, 2007 | 03:26 PM
SpectreR1's Avatar
Did you make sure both your pumps are working?
(Though I'm used to bronco's but the F150 should be the same.. A low press pump in the tank and then a high press pump inside the frame rail by the drivers side door..)
Old Apr 9, 2007 | 08:50 PM
The 92 and newer f150 has a one high pressure pump per tank. My truck had the rear tank removed when i bought it, so i can't compare the two pumps.
A looks like about $75(Canadian) for a pump. so i'm not too worried plus this is my "playin" truck so no rush
Old Apr 9, 2007 | 09:04 PM
Bruce R Leech's Avatar
you might check the regulator.:
bandito:
Bruce
Old Apr 9, 2007 | 09:07 PM
hay Steve what hapened to your signature link? it is gone, I am sad.
Old Apr 9, 2007 | 09:11 PM
Its just gone in this thread.
the link to efi is:
http://www.supermotors.net/vehicles/registry/2742/12737
Old Apr 9, 2007 | 09:45 PM
adrianspeeder's Avatar
Not quite, it was '90 and up.
Originally Posted by SpectreR1
...A low press pump in the tank and then a high press pump inside the frame rail by the drivers side door...
That would be '85-'89 302's, '87-'89 300's/351w's, and '88-'89 460's.
Adrianspeeder
Old Apr 10, 2007 | 01:46 AM
cavinandpavin's Avatar
you mean i missed having a 2 pump system by one year!!! dayum! i got the 3 pump deal. has any one put the 89 up pumps in an 88 and older truck?? i hafta buy the rear lift pump anyway so would be better off to replace both with the high pressure later model ones??
Old Apr 10, 2007 | 11:42 AM
Steve83's Avatar
adrian
I'm pretty sure it was '90 when they went to the FDM (in-tank only) system, but I haven't done a LOT of checking on it.
c&p
My truck runs on a '96 tank & lines.
Old Apr 10, 2007 | 02:16 PM
subford's Avatar
Originally Posted by Steve83
adrian
c&p
Yes it was 1990 for the F150 (F-series) Gas and 1991 for the E-series Gas when they went to the FDM (in-tank only) system.
Old Apr 10, 2007 | 02:34 PM
Ok, thats what the haynes is showin'. I swore when I was junkyard searchin' for a tank it was an '89, but maybe it was a '90.
Adrianspeeder
