Steve!!! :)
Old Mar 25, 2007 | 12:34 AM
buzzsaw714's Avatar
Steve!!! :)
heyyyy its me buzzsaw haha, the person that needs your help 24/7.. anyways... on super sharp turns on my truck tires do rub a little... I dont think much of it ever.. but anyways. how do I redo my spedo.. that post is really confusing! I hold reset or some crap then set it to 9.18? i just wanna check with you before i do something stupid and screw it up. I use the e4od tranny on i6 4x2
Old Mar 25, 2007 | 08:34 AM
PKRWUD's Avatar
To recalibrate your speedometer after changing tire sizes:
Start with 20186, divide by actual tire size in inches.
Divide again by 66.66.
Example:
20186 / 31 = 651.16
651.16 / 66.66 = 9.77 (rounded up)
Thus for 31" tires, the calibration number is 977.
To set the calibration, ground the single wire connector under the glove box (often Lt. Blue wire w/ a Yellow tracer, but you might want to check a manual for specifics), hold in Reset button on trip meter and turn ignition to ON. After the speedometer needle cycles from zero to top speed and back to zero, press Reset button again. You should now see the calibration # that you currently have. From here, use Select to get proper calibration, and press Reset to store.
When you press Select, the number only goes down, but don't worry if you need a higher number. After you reach a certain number (400 or 500 I believe), it will start back at the highest number the speedo can be calibrated with (often 1100), and go down again.
Notes:
Larger tires will require a smaller calibration number.
If your new calibration number needs to be larger than the highest number allowed, just go with the highest number allowed.
If you shut your ignition switch OFF before you press Reset to store the new calibration number, the number will remain what it was before you started.
With stock 235-75 15's, the calibration number should be about 1044, but you may find that it's been set at 972 from the factory. This means that your odometer has more miles on it than you have truthfully traveled.
WARNING:
You can only change the calibration number 6 times without replacing the module.
Old Mar 25, 2007 | 03:47 PM
buzzsaw714's Avatar
what does grounding a wire mean? :P
Old Mar 25, 2007 | 04:42 PM
csonka
Guest
Posts: n/a
Oh boy. Well let me look around here for the link. This has been posted before.
Old Mar 25, 2007 | 06:29 PM
usedtodrivechev's Avatar
i had no idea you can do that!!!!
mine says 972. but i put 31's on so its pretty close. but i didnt ground it so i guess thats why i couldn't change it.
when you first turn it on it says "E8 06" whats that mean? and when you push select on the first screen it displays "1111111.." then "2222.." and so on. whats that mean?
Old Mar 25, 2007 | 06:53 PM
PKRWUD's Avatar
It means using a jumper wire to connect the wire in question to ground.
E means English, 8 has something to do with the revision number, and the 06 tells you how many times you can change it before becoming locked out from being able to change it.
The numbers you saw are simply there to test the digits on your digital odometer.
The reason you couldn't change yours is because you didn't ground the enable wire. You can check your calibration code without grounding the wire, but you have to ground it to make any changes.
Old Mar 25, 2007 | 10:07 PM
Steve83's Avatar
Just for future reference: I have a pet peeve about being "called out" in the subject of a thread, or even in the text of the thread. I don't want to be the subject of a thread in a technical forum, and naming someone in a subject line can only REDUCE the number of other users who read the thread & post info to it. So I actively discourage it by ignoring any thread with someone's name in the subject (especially MY name) for at least a day - usually 2 or more. Just ask your question - anyone who can help you will post. Stating that you only want one user's opinion not only discourages anyone from helping you in the future; it also makes it seem like you're depending on & expecting the person you named to do all the work of helping you. That's not gonna happen, so there's no point in asking for one person. By posting to a public BBS, you have access to a whole WORLD of knowledgeable people, so don't limit your options.
Another of my pet peeves is a subject line that DOESN'T contain the subject of the thread, but that's self-explanatory.
Anyway, back ON-topic:
Everything you never wanted to know about the PSOM ('92-96 speedometer) is described in this thread, which incidentally is linked in another thread here on F150online.com. You'd have found it if you had searched, so I recommend doing that first next time you have a question.
Old Mar 25, 2007 | 11:28 PM
oh snap!
Old Mar 25, 2007 | 11:33 PM
buzzsaw714's Avatar
sorry :'(
Old Mar 25, 2007 | 11:40 PM
csonka
Guest
Posts: n/a
Eh, I would say that was appropriate. At least it wasn't a flame. Just be sure to follow forum protocol next time man. Remember, search is your friend too.
Old Mar 26, 2007 | 06:54 AM
adrianspeeder's Avatar
What size tires?
Adrianspeeder
Old Mar 26, 2007 | 01:38 PM
csonka
Guest
Posts: n/a
I believe I saw somewhere 31x10.5 R15
Old Mar 26, 2007 | 03:55 PM
buzzsaw714's Avatar
ya it is :\ 31x10.5x15
Old Mar 26, 2007 | 04:16 PM
csonka
Guest
Posts: n/a
9.18 is the correct number for your tire size. Did you figure it out?
Old Mar 26, 2007 | 04:24 PM
buzzsaw714's Avatar
no :\ thats why i made a post twords steve becuase i dont understand his other posts... and i made it a post becuase i thought other ppl would have same problem but he got mad :\ i dont know how to reset it or how to ground the wire or that stuff :\
